    Results 1 to 20 of 30
      Texas
      Should I Pull The Trigger??
      Not totally new to the LSx scene or LS1 tech, but new to the idea of swapping a LSx into my 72 Chevelle.
      I am considering buying the E-Rod LS3 package since I have noticed a significant price drop ($1500 less than the below link) on several. Is there any reason why I shouldn't go for it? Huge advantage is that it comes with the engine controller which is around $1000 alone. Everything said...total 'drive out' $6200ish.
      Also, does the drive by wire pedal that is included bolt right up to older vehicles (70-72 A Body, specifically)?
      http://paceperformance.com/i-6255562...nsmission.html
      Texas
      I figure I will ditch the cats and run regular long tubes, swap oil pans to work with the A-body, find p/s pump and bracket, alternator and bracket, add electric pump to tank or buy complete unit, find 4l80e tranny or use transdapter flexplate for my existing th350.
      One of my biggest questions centers around the pedal assembly and if it will bolt right up in the Chevelle. I'm guessing there will be some fabbing to be done, maybe??
      Indiana
      We put an erod LS3 in our 66 Chevelle a few years ago and have beat it like a rented mule since. [ask anyone who has chased me around the autocross or road course ] It is unbeleiveably smooth, powerful and reliable. The package is also the most complete adn well thought out system I've ever used [and I've used a lot of them]. On a scale of 1-10...it's at least a 13.
      Here is a link
      http://www.ridetech.com/garage/1966-chevelle/
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Jun 2012
      South Lyon, MI
      It's a great package with very little hassle. But I can't tell you if the pedal bolts right up.
      A friend of mine who owns a speed shop where I used to live in Michigan put this package in a '79 Camaro he built for David Freiberger of Hot Rod Magazine. It was real nice and also trouble free. He installed a lot of LS motors and really liked this LS3 E-Rod motor assembly.
      Texas
      Quote Originally Posted by bret View Post
      Here is a link
      Thanks, Bret!
      Can you expand a bit on how you did the DBW pedal? Did you use it and fabbed something up or did you go another route? I'm trying to come up with a real world budget (wish I had a RideTech budget..lol) and weigh my options. I'm really excited about getting started, but don't want to do anything impulsive. I think I can handle all the other related issues - efi fueling for tank, oil pan, accessories.
      Birmingham, AL
      I used to think that was a lot of money to spend on an engine, but LSX swaps can nickel and dime you into a pretty high price. I have an L92 block that I bought for 600 that needs freshening up and at least a hone so that will probably be 1000-1500 for machining/bearings/bolts (maybe 700 more if I have to go to a 4.070 piston), then a cam swap at 350 or so, LS3 intake that I scored for 200, LS3 heads for 600, accessory drive 300 used, oil pan 150, headers 250, wiring harness/ecm will likely be in the neighborhood of 1000 and a few other things I am not listing. I got good deals on most of this, but it has taken about two years of patience to score these deals. Some of the prices I listed are more the average price and I paid a little less, but you get the idea. You can either write the check and know what you are getting in a crate motor or spend little by little to build the engine you want.
      Stephen
      Texas
      Quote Originally Posted by srh3trinity View Post
      Yup! This is the exact reason I am considering buying this. I have gone back and forth between LS1, LQ4, LQ9, LM7...all from salvage yards for cheap. But every single time I started adding in the things it would take to complete the swap, I keep ending up back at $6k-7k.
      Birmingham, AL
      I had a junkyard LQ4 first and parted it out, made my money back and then swapped the block for a transmission core. I didn't have the money all at once to drop on an Erod engine, but when I look at the totals above, I would be pretty close if I had just saved and bought it. I will probably wind up with upgraded pistons, ARP bolts, upgraded valve springs and a different cam and I will be under the cost of an LS3, but again, it took a lot of sourcing and patience to get this far. If you are moving forward on a project and are waiting on an engine, sometimes you pay a premium for availability.
      Stephen
      Texas
      Agreed!
      Okay....couldn't resist. I purchased it!
      Next order of business - Accessories and other necessary items for the swap.
      What can you think of that I need to complete the swap?
      1. long tubes
      2. swap oil pans to work with the A-body (maybe use the CTS-V)
      3. p/s pump and bracket
      4. alternator and bracket
      5. add electric pump to tank or buy complete unit (too frikkin expensive)
      6. locate 4l60e/4l80e tranny or use transdapter flexplate for my existing th350.
      7. conversion motor mounts
      8. ?????
      I'm sure I'm forgetting things so your help is much appreciated.
      Birmingham, AL
      The 98-02 F-body accessory drive and the GTO accessory drives are probably the most compact. I am not sure about A-bodies though. I am doing an F-body build and using an F-body accessory drive and oil pan. Start a new thread in the LSX section or do some searching on here and LS1tech to see what other A-bodies have done.
      Stephen
      Indiana
      Quote Originally Posted by novajess1972 View Post
      Agreed!
      1. long tubes
      8. ?????
      We're running ours withthe supplied cast iron exhaust manifolds and the 4 cats, a 2.5 exhaust and flowmasters. Minor trimming on the lower rear control arm mounts. Quiet as a taxicab at idle...nice snarl at full throttle. It made 369rwhp. It feels a bunch better than that. We used a Holley cast aluminum pan and engine mounts. ...no problems on the autocross or road course. We used a Ricks tank, but the oem tank could be adapted with a vaporworx fuel pump system. We ended up using a Vintage Air Frontrunner for accessories, but some time adn fab skills could make the supplied GM drive system work fine.
      Bret Voelkel
      Indiana
      Thanks, Bret!
      Can you expand a bit on how you did the DBW pedal? Did you use it and fabbed something up or did you go another route? I'm trying to come up with a real world budget (wish I had a ridetech budget..lol) and weigh my options. I'm really excited about getting started, but don't want to do anything impulsive. I think I can handle all the other related issues - efi fueling for tank, oil pan, accessories.
      We used the supplied DBW pedal...bolted right up. We may have drilled a couple holes for mounting, but in the scheme of things that we regularly make [or invent] that didn't even come up on the radar.
      Bret Voelkel
      Birmingham, AL
      That is a lot of HP with 4 convertors!
      Stephen
      May 2008
      Chicago
      The pedal bolts in but I cut the pedal rod and rewelded it to change the angle for comfort. I say you do it, I have an LS2 in my 67 Chevelle and love it.
      Jun 2009
      Central FL
      Agreed!
      1. long tubes
      8. ?????
      1) Yes, get longtubes, I thought for a while about it, anything else would be a waste of money, you'd end up with LT's anyway.
      2) Not sure about A-bodies, but I got a Mast for my swap, and it's super compact and really nice. If you're interested in one, find Daytonayellaz on here.
      3) Fbody/GTO hug the block the tightest, Corvette acc's are nicer, because you can actually access the stuff and the Alt is on top
      4) PS and Alt are the same bracket
      5) Buy complete, Tank's Inc or check the LSX subforum for a 90's Caprice fuel tank swap for Abodies (super cheap).
      6) 4l60e's are cheap. They also suck, but will work unless you build the motor.
      7) Carshopinc
      8) !!!!!!!
      Any more questions, fire away.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Birmingham, AL
      I like Dan's response to number 8.
      Stephen
      Alabama
      Did you mean you found it for $1500 less than the Pace link above ? Where?
      Wake Forest,NC
      One thing you need to check on, I think the ecu is locked out which means you can't tune it, so if you start changing things ( like deleting the cats) you might have problems. I think it's locked so that they can get the smog legal cert.
      Texas
      Quote Originally Posted by barraza View Post
      Yes. It was actually through Pace. They were running a deal on them. It said that it was the last one left before I purchased. I kind of thought it was some BS just to get people to buy, but after purchase I checked back on the site and it now says Not Available. Couldn't post the original link earlier and have someone snipe the last one out from under me. Sorry.
      http://paceperformance.com/i-7134233...-old-part.html
      Quote Originally Posted by 71RS/SS396 View Post
      Damn! I will have to look into that. Thanks for the heads up.
      Quote Originally Posted by Vicinity View Post
      7) Carshopinc
      8) !!!!!!!
      Thanks, Dan! This will be very very helpful in my quest to source parts/accessories. I'm sure I'm not done with you, though. LOL.
      Quote Originally Posted by kochevy67 View Post
      Sweet!
      Even sweeter!
      I appreciate everyone's input. I'm hoping to have her installed and on the road by Thanksgiving. That's ambitious, considering my schedule, but gonna shoot for it anyway.
      Cartersville, GA
      I have a '69 Chevelle atthe shop right now for an engine swap...LS1/4L80E...and it is equipped with BRP/Musclerods mounts and 1 7/8 longtube headers (fit great), a GMPP "Musclecar" pan kit, and Kwik Performance accessory brackets. I don't have any pics right now, but I can get some in the morning if you are interested in seeing it. It has a cable-style throttle body, but we have done several cars with the GM DBW pedals, and while they aren't always ideal out of the box, they aren't too hard to mount up in just about anything. On a '69 Camaro we did recently (Trailblazer SS pedal), we combined the TBSS pedal with a nicer-looking Lokar pedal that was previously installed in the car. It was fairly easy to do, and was a nice touch to make it better match the brake pedal.
      Joe Hinds
