Results 1 to 12 of 12
Thread: clearance issue
07-31-2005 #1
New to Pro-Touring
- Jul 2005
- Texas
- 17
clearance issue
Since I am wanting to lower the rear of my car I figured I should first crawl underneath it and check out my options and see how much room I have. While under the car I noticed something that is quite bothersome. My body or axle is causing different clearance measurements on each side of the car. on the driver side I have 1 and 11/16" between the tire and fender, giving me a decent amount of room above the tire for the body to come down. But on the passenger side there is only 13/16" between the tire and fender, leaving no room about the tire to lower. The reason it affects the room above the tire is because of the curve in the fender well. I believe it is because of the body, but have no idea what is causing it or how to fix this. Here is a quick diagram I made to give you an idea of what Im talking about.
