      May 2006
      Rhode Island
      incorrect valve lash adjustment symptoms
      I have a small block chevy, It ran fine on saturday after I put the motor back together from putting new head gaskets on. I figured I'd adjust the valve lash since I pulled the rockers to replace the valve seals. tonight I tried doing the adjustments, and now it runs like dog ****, studders and shakes like a *******. would this be because I have the valves hung open? I've never tried to do the adjustment, and I heard it was easy, but I'm not thinking it was.
      Rene P.
      Midwest
      Sounds like either mis-adjusted valves, maybe a missing vacuum line, or both... what procedure did you use to adjust the valves?
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      May 2006
      Rhode Island
      http://www.chevyhiperformance.com/te...g_valves_info/
      Used that, but instead of bumping the motor, we turned the crank with a ratchet. We must have done it incorrectly, although we think we followed it pretty good.
      Rene P.
