      Phoenix,Arizona
      Sanden SD-7 Compressor Fittings
      I bought a Vintage Air kit for my Dads Camaro a while back but it did not come with the air compressor connections. It just has a block off plate. Ive tried to do some research on where to get these connections but have come up short. From what I know its a Sanden SD-7 compressor. If you guys know where to get them let me know. Thanks!
      Here is a pic of the compressor/block off plate;
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Santa Clara, CA
      Look at the March P418 and see if that works in your situation? I've usually seen those compressors mounted with the fittings pointing up, not to the side as in your application, so it might not work. Plus, I have no idea what I am talking about.
      Steve
      Jun 2005
      Lynnwood Wa.
      Check Classic Autoair.
      they can put together any combination of hose and fittings
      you might need.
      http://www.classicautoair.com
      2X on the compressor fittings. They need to be within 45 degrees of vertical.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      San Antonio, TX
      Adapter fittings for Sanden SD7b10 (7176) available at Vintage Air
      Hi Brian,
      I assume by Vintage Air kit you mean the A/C system minus compressor. The accessory drive you show appears to be a Wegner (which is compatible with the rest of your Vintage Air system). The adapter fittings for the SD7b10 compressor are included with our Front Runner accessory drives and are compatible with our hose kits. We stock two styles of fittings that will fit the compressor on your accessory drive. The standard adapters that ship with our Front Runners are PN 045008-VUR and 045010-VUR for unpolished and 045011 and 045012 for the polished version. These fittings are on page 65 of our current catalog here. The upgrade fitting is on page 59 of our current catalog here and is part #242310 or 242311. They're all in stock.
      Ryan Zwicker
      Vintage Air, Inc.
      KUL FIR CHICK N: COOL FIRECHICKEN
      '68 Firebird, LS7, 6spd, DSE all around.
      Phoenix,Arizona
      thanks guys, that really helps. Ryan, Ill probably be in touch with you soon on those fittings.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Santa Clara, CA
      Thanks for posting this thread! I also have a Wegner kit but I haven't installed it yet; I didn't realize that the compressor mounts with the ports pointing to the side like that, but that makes sense. In that regard, the March P418 would not work, I don't think, because it would wrap all of the way around and the outlets would be pointing straight at the engine (points 180* from port surface). The Vintage Air unit (342310 & 342311), on the other hand, does a nice 90* change, so that would be perfect for this install. Saved me some embarrassment and a product return!
      Steve
