    Results 1 to 16 of 16
      Oct 2007
      New Tampa Area
      Custom Center Console Finish Options
      Hi, I am just about finished building a Custom Fiberglass Console for a 67 Dart and would really like to finish it in a way that is similar to the vinyl textured plastic that many of the OEM used (Semi Gloss Black).
      What would be the best way to achieve this?
      Darin
      Jul 2012
      My best advice would be some type of Naugahyde. Do you have a Joanne fabrics or something similar near you that you could check out fabric swatches.
      Oct 2007
      New Tampa Area
      Thanks for the reply.
      I do have Joanne fabrics, but due to the contours of the console I was really trying to find a paint solution.
      Not sure it could be covered with vinyl.
      Erie, PA
      I used black wrinkle paint for the console to match the hard plastic of the dash closely...
      Andreas
      www.fgmcc.com
      Oct 2007
      New Tampa Area
      Thanks I will give it a try
      May 2010
      hephzibah, georgia
      I had mine dipped in a carbon fiber material, same as the material that used on the golf carts ex. realtree, turned out awesome with about 6 coats clear on it. Most companys has different patterns to choose from.
      Oct 2007
      New Tampa Area
      Greedreams69: that sounds cool can you post a picture?
      I included a picture of the console I am building and need to paint/cover.
      Darin
      Jul 2009
      Cypress, TX
      Looks good. Have you considered an automotive wrap? Leather/vinyl print wraps are available, or you could go with carbon fiber, brushed aluminum or many other finishes.
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      Jul 2009
      Cypress, TX
      I bought some from this guy on ebay.com.
      http://www.ebay.com/itm/120901538354...84.m1497.l2649
      Jul 2009
      Cypress, TX
      Jan 2012
      Fort Wayne, Indiana
      Wow Terry that looks great, can you send me some pictures when you get it installed.
      Mike
      MCI
      May 2010
      hephzibah, georgia
      Darin, shoot me a email to [email protected]. I think you would like end results. I had my Detroit dash done as well
      Oct 2007
      New Tampa Area
      Terry that looks great! How hard was it to apply and is it textured or just an optical allusion?
      Darin
      Jul 2009
      Cypress, TX
      Darin,
      Looked easy, but I had it applied by a company that wraps cars. Dropped it off on the way to work and picked it up on my way home. I assume it was pretty easy since they did it so quickly. The material is actually textured - it really does look like leather, but it's thin enough that it still shows all the countours of the center console. The wrap is applied directly to the fiberglass (no padding). I'm very happy with the look, but don't know how durable it will be.
      I'm installing an alarm, power window switches and a power lock switch in the console, so it's taking me a while to get the wiring all done. But, we should have it all done by this weekend. I'll post a pic when it's all in.
      Terry
      Houston, Tx
      Quote Originally Posted by terrydmorgan View Post
      Darin,
      Terry
      Where did you get this done? Looks like near Houston if you are in Cypress... This is exactly what I am after. Do you have pictures of the console pre-wrap?
      Chris
      Jul 2009
      Cypress, TX
      Chris,
      I used Wrap It USA (www.wrapitusa.com). They're located on the west side of Houston on beltway 8, just south of 290 (5829 West Sam Houston Pkwy N).
      The console is from Modern Classic Interiors (http://www.modernclassicsinteriors.com/).
      Terry
