      Sep 2012
      Alignment specs for lowered 68 camaro
      What is the best alignment specs for a street driven 1968 camaro with 3" Lowering springs front and back. and 225/45zr17 on the front with 275/40zr18 on rear my other suspension mods are as follows
      front
      1" addco sway bar
      polyurithane suspension bushings
      front disc brake conversion
      3" lowering springs
      stock control arms
      everything bead blasted and re painted
      Rear
      7/8" addco rear sway bar
      3" lowering springs
      rear disc brakes
      slide a link traction bars
      subframe connectors
      polyurithane bushings
      Nov 2010
      southern wva
      Do a search over for David Pozzi racing. He knows first gens
      Indiana
      The OEM early Camaro suspension has a terrible camber curve...it actually looses camber in compression...meaning that when you enter a turn, the tire leans away from the turn instead of into it.
      So...run a larger than normal amount of negative camber, around 1 degree to 1.5 degrees.
      Caster - as much as you can feasibly get...4-5 degrees of positive
      about 1/8" toe in.
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Milwaukee, WI USA
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
