      polk county,FL
      building an EFI system with LS electronics ?
      As the title states. My plan is to build a 383 to replace my worn engine. I would like to FI it, but build my own system. I have the tools and skills to fab up my own intake using a factory style throttle body and factory style injectors. I would prefer not to use a mega squirt ECM. Can LS electronics be adapted to use like this?
      Mar 2011
      St. George, UT
      Getting the correct 1x cam and 24x or 58x ( depending on computer year) crank signal for the computer to work correctly may be a challenge.
      These guys specialize in exactly that:
      http://www.eficonnection.com/eficonnection/default.aspx
      ​John Parsons
      Walton, NY
      You can do OBD1 GM pretty easily rather than OBD2 LS stuff. No crank trigger, etc needed. That's the route I'm going since my other two are already OBD1.
      Mar 2011
      St. George, UT
      Awesome info thanks for the link.
      polk county,FL
      Thanks guys. John, that's what I'm looking for thanks. I had actually check out their stuff before.
