      Jul 2011
      NC
      LS3 Power steering pump coming apart?
      Has anyone ever heard of the stock LS3 GM power steering pump shaft getting pulled out of pump under high HP applications? I know this is a press on pulley but it seems to have moved on me over the weekend. Possibly happened under high RPM? my belt is now missing a rib and it appears the PS pulley is the culprit.
      It was also heating up a bit during auto x so I think I want to remote the reservoir anyways...
      Any ideas what pump/pully combo would be a good replacement for 10/up camaro drive setup?
      Josh
      Josh
      "Schism"
      69 camaro
      Jul 2011
      NC
      Anyone had this issue before?
      Josh
      "Schism"
      69 camaro
      May 2002
      Northern California
      Is the pulley coming off of the shaft or is the shaft coming out with the pulley? I have seen the shafts break on Jeeps, grab the pulley and pull forward. A new pump will fix it.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jul 2011
      NC
      Ok- got it figured out & fixed... Pulley was being pulled off shaft- by torque im guessing...
      Fix-pressed back on all the way & put a 3/8 x1" bolt with washer in the threaded hole... Dealership says no bolt is suppsd to go in there but i need one! Should hold now...
      Josh
      "Schism"
      69 camaro
