Results 1 to 9 of 9
Thread: Temperature problems
09-10-2012 #1
- Oct 2010
- 8
I have a 72 Vega with a sbc 355 and after putting a new water pump, problems beggin. The original setup was Camel Hump heads, forged flat top pistons, forged rods, nitrurated crank, among other things. We changed the original water pump for a Weiand, and temperature started to elevate, also do pressure.
We changed heads for a set of aluminum Pro Comp 58cc combustion chamber and 210cc runners, and thing just got worse. It seems like compression is going into the water cause there is a lot of pressure in the cooling system, a pressure that IMO just can be created by the engine compression. We pressure checked everything (magnaflux and all the rest), and there was nothing wrong.
Now the engine is dissarmed waiting for a new camshaft which I'm choosing yet (accept ideas) and still thinking about my problem and the possible causes of it. One of my theory comes along the elevation of the intake water neck and the rad; the water neck is about 4" higher than the top of the rad. We install a water neck with filler and the problem remains. We changed head gaskets, and nope; theres pressure yet.
I don't know if some of you have ever experienced something like this, but if you could give me a hand, some ideas or advice I'd be very apprecciate it.
Thank you very much and hope you can help me.
Cheers!
