    Results 1 to 9 of 9
      austria, where the kangaroos go skiing
      Country Flag: Austria
      bbc clutch on ls2
      so it seems like iīm swapping my 540 to an ls2 engine and now the first questions are coming up. i have a keisler tko600 behind the bbc with a brand new mcleod rst dual clutch. is there a possibility that the bellhousing and the clutch are gonna fit on the new engine and itīs flywheel or do i have to swap out all the parts?
      thanks,
      pat
      69 camaro, 418cui p1sc1, ridetech,forgeline, and some more money wasted
      Dec 2010
      St Louis
      If it's a 621 bell, it will bolt up to the LS, minus 1 bolt hole.
      If the clutch is drilled for a standard 11" big block flywheel pattern, therres a good chance bolt up to a sachs 1050 flywheel.
      You'll also need an LS7 pilot bearing.
      Info with part numbers.
      http://ls1tech.com/forums/conversion...-ls-motor.html
      And if you want to save a few lbs, an aluminum flywheel. Not sure what it's drilled for though. BTW the $200 price is marked down from Mcleods $800 list.
      http://www.racingjunk.com/Clutches/1...el-Chevy-.html
      yep thatīs what i have read in several forum posts but just wanted to make sure. i have the 621 bellhousing so that should work out. the mcleod clutch is this one http://www.summitracing.com/parts/MCL-6911-07 i mean i can buy a ls clutch but if theres a slight chance that this clutch will fit i would be more than happy to get a flywheel to make up the difference. but thatīs a really good writeup on ls1tech, thanks gary
      Dec 2010
      St Louis
      Just an FYI with the sachs flywheel. It has a larger center cutout leaving the inside 3/4" of the disk of the 11" BBC clutch disk not contacting anything. No one has had an issue that I've seen. But with a smaller clutch, you may have problems.
      ok.....thanks
      just if anybody ever searches for info......i got this mcleod 560535 aluminum flywheel + .400 or the 460535 steel flywheel +.400 will fit the dual friction BBC clutch and mcleod recommends the standart chevrolet pilot bushing. badass deal with mcleod over racingjunk, paid 250$ shipped, summit wants 700$ for this flywheel. thanks again gary for all that info on ls1tech
      Dec 2009
      Dayum Gary! I paid double for my Mcleod alum flywheel just a month ago...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Dec 2010
      St Louis
      The pilot bearing has nothing to do with the flywheel, it's mounted in the crank. They might prefer a bushing over a bearing, bit I've never seen one for an LS crank. The standard f body seats in the deeper drilled out section of the crank, so a Muncie/TKO input shaft wont reach it. You will need the LS7 pilot bearing that seats in the larger, outer area.
      Quote Originally Posted by camaro427-69 View Post
      i placed the bearing already in my summit cart with the gm part nr. you have on ls1tech ;)
