    Page 5 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 ... LastLast
    Results 81 to 100 of 251
    1. #81
      Oct 2011
      Katy, Tx
      Great progress...
    2. #82
      Sep 2009
      Annecy France
      Country Flag: France
      very interesting and really good work !! thanks for sharing, I will do something similar next year !!
      69 mustang in the built
      70 cuda 440 in restoration
    3. #83
      Indiana
      I have a few updates to share. Slowly but surely I'm making progress...
      Since there aren't any decent two post radios, I cut my dash for a single DIN head unit. It goes good with the Vintage Air control panel and powder coated ash try door.
      I made a panel to mount the ridetech AMK compressor and valve body. I welded the panel to the upper shock crossmember so the components can hang below out of site but are still easy to access.
      I got the inner rocker panel and pillar bottoms in.
      Before I put the rocker on, I want to replace the rear cab corner but the replacement corner is way off. I guess I'll have to cut it in two and remove the excess and put it back together. Unless there's a trick to this that I don't know about.
      Even though the floor pan looks bad, it's actually pretty solid with some small holes. So instead of opening yet another can of worms, I decided to POR-15 it and add some of their mesh to help strengthen it. The final goal will be to have the entire floor pan Linex'd.
      Finally, one of ridetech's very talented employees pulled the dent out of the passenger fender.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    4. #84
      Jun 2012
      N. Shore, Ma
      "replacement corner is way off"
      Yeah I had the same problem when I welded up my buddies 61 Apache, you have to get creative.
      Lookin good though!
      Eric
      Building 1969 GTO - Roadster Shop chassis, LQ9 w LS3 heads and rebuild parts from TSP, Bowler prepped Magnum T56 6 spd, 3 Link Strange 9" w Speedway Floater Hubs, Wilwood 14" F - 13" R brakes, 275.18 - 345.19
      https://www.pro-touring.com/threads/94970-69-GTO-Build
    5. #85
      May 2007
      Mooresville, Indiana
      Love the work you're doing Herb!
    6. #86
      Indiana
      Quote Originally Posted by ekmxryda View Post
      Lookin good though!
      I was afraid of that! Thanks!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    7. #87
      Indiana
      Quote Originally Posted by tommycomfort View Post
      Thanks! I'm figuring it out as I go... never did sheet metal work before.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    8. #88
      Nov 2004
      Tupelo,MS
      Looking great Herb!
      Hmmmm, You going to be able to match the paint on your fender repair?
    9. #89
      Indiana
      Quote Originally Posted by 67MAL View Post
      Looking great Herb!
      Probably not. It might end up being a primer spot along with the rockers and cab corners.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    10. #90
      Jun 2010
      Georgia
      looks like it's coming along well. Any plans to bring it south this year to any events?
    11. #91
      Birmingham, AL
      This would be hard to describe in typed form, but with the cab corner: Tack it in place after getting the curved area to fit, then use a cutoff wheel to cut down the line of the door jamb. Then take the piece that you cut down which would be a right angle piece and flip it over and weld it in as the continuation of the door jamb. Then trim it up. Or, if the metal in the jamb itself is in good shape, just trim it to fit and butt weld it.
      I hope that makes sense. There may be a better way to do it, but that would be the way I would be tempted to do it.
      Stephen
    12. #92
      Indiana
      Quote Originally Posted by SparkyRnD View Post
      Thanks! As for events, if I don't have the El Camino and/or Chevelle back together, the '63 may be my only choice...
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    13. #93
      Indiana
      Quote Originally Posted by srh3trinity View Post
      I think I understand what you're saying. I hope to get the corner on and the rocker at least started, possibly on, this weekend so I'll let you know how it goes.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    14. #94
      Jun 2010
      Georgia
      when I was a kid, I had put money down on a 63 fleetside. Came back a day later to pick it up and pay the balance, guy sold it out from under me. I did get my money back, but always regretted not having that truck. If you come south, I'll be there to check it out in person
    15. #95
      Woodbine, MD
      Looking good buddy!!!!!!
      Douglas Lutes
      1988 Monte Carlo SS
    16. #96
      Jun 2010
      ottawa ontario
      lookin good man!
    17. #97
      Nov 2004
      LYNCHBURG,OHIO
      Cool project Herb! I dig it! Hope to see it at an event this year!
      Greg Tholen
      GT Motorsports
      Dealer for Wilwood,Baer,Viking,Moser,BMR,Earl's
      (937)763-7272
    18. #98
      Indiana
      Progress on the truck has been pretty slow lately, mostly because I've been caught up in a side project...
      Yesterday and today I actually worked on the truck. The rockers aren't done yet, but I had to do something that could be accomplished in a weekend... so I removed the rusted and busted core support...
      and in it's place I installed this very trick core support and radiator from AutoRad! The only down side is once all the body parts are back in place, not much of it will be visible.
      Maybe now I'll be motivated to get the rockers done!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    19. #99
      Birmingham, AL
      That core support is a nice piece. I like the look of the shop
      Stephen
    20. #100
      Indiana
      Thanks! The question is which one will be done first?
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
