      Orlando, Fl
      Yet another C5 brake question
      Ok, I looked through the archives and figured out I need to run a 13/16" or 7/8" inch bore master cylinder running manual brakes on my 73 Z/28. What I am having a problem with is finding someone that sells one. I have found tons of 1" MC's. And a pretty sweet Wilwood aluminum master cylinder, but the mounting bolts are rotated 90 degrees. I could easily machine a bracket to run that one, but just to make it easy, I was wondering if I could just find a factory MC with the right size bore.
      Thanks in advance.
      Nick
      I am using a stock C5 master on my 1970 corvette with C5 rotors and calipers. I also have manual brakes. I had to space it away from the firewall and drop it down a little. The bracket uses the existing booster holes in the firewall.
      I can get you a template if you are interested.
