    Results 1 to 15 of 15
      Mar 2011
      Drip rail removal
      I'm no pro... just a guy in his garage. Never messed with a drip rail before and never done body work at all prior to this car, so take it for what it's worth (not much).
      A good place to start with drip rail removal is with a decent drip rail.
      After you find a decent drip rail, you'll need a good way to destroy them.
      I prefer the grip and bend the hell out of it method.
      After it's all bent, its time to chop. I took a page from someone else's book and did the chop/tack weld method. (6 inches at a time)
      After the whole thing had been chopped off and tacked, I welded between the tacks and cleaned it up with a flap wheel.
      End result = no drip rails...
      Dec 2009
      Nice job! I remember doing it exactly as you did. Scared the carp outta me. :yes:
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Mar 2011
      Quote Originally Posted by Ron.in.SoCal View Post
      Sep 2009
      Atlanta,Ga.
      I cant wait to start on mine. So once you bend the drip weld you will be able to see the seem you have to weld? I will be doing this with a 1970 cutlass.
      I am SUCH a rookie to Pro-Touring
      Mar 2011
      Quote Originally Posted by DreKoushRanada View Post
      What you see in the pics is exactly what it looks like. Once you bend it down there will be a little seam sealer and a joint of two panels. On the Camaro, the panels are offset by about 1/2". I cut about 5/8" off, welded, and ground smooth.
      Sep 2009
      Atlanta,Ga.
      Thanks for the info. I hope to start on it this weekend.
      Sep 2009
      Atlanta,Ga.
      Do you thing the Harbor Freight 90 amp flux core welder would be good for this project?
      Aug 2008
      jacksonville,fl
      Flux core welding is quite messy for something you need nice like bodywork on thin sheetmetal.
      Dec 2011
      San Diego, CA
      ok so this is definately now on my to do list
      looks great
      -Blake
      yellow 72 nova in San Diego
      Nov 2009
      Austin Texas
      I want to do this but as everyone else said it scares the crap out of me. Anyone else have pictures of what they did?
      Jonesboro, Arkansas
      Quote Originally Posted by cwylie View Post
      Man, I'm right there with you. Although I would like to have a little bit of a roll there at the place where you welded it. It scares me too, probably why I've not done it yet.
      Carl Wilson
      Mar 2014
      Mesa, AZ
      I skipped the bending part when I did mine and just cut them off in small sections, but that way works too!
      I've got some pictures of cutting mine off my 69 Chevelle in my build thread. I can put them here later if people want them here.
      Here' the build thread: https://www.pro-touring.com/threads/...e-Smasher-quot
      Nelson
      Dec 2008
      Im rebuilding the corners of my roof just above the a pillars, I was considering cutting the drip rail off I have been trying to search and find this so I can see how it was done and finish look....I can not see the pics? can someone forward them to me? [email protected]
      Aug 2008
      jacksonville,fl
      You can't bring back pics once the original poster removes them from an original source such as photobucket.
      Here's a couple more threads on the subject
      https://www.pro-touring.com/threads/...p+rail+removal
      Dec 2008
      thanks I am still on the fence,I have a friend that is having his done as we speak...I guess I need to go see in person before I commit!
