    Results 1 to 12 of 12
      Aug 2012
      Pennsylvania
      67 Mustang Fastback Build....
      Hey guys,
      I am almost finally at the point where I need to make final decisions on front and rear suspension. 4-link for the rear, and IFS for the front both with coilovers. I will be using a 9" with disc brakes and 20x10 wheels (I mini tubbed it!!), and up front I am installing a 2011 Coyote (Whippled) with 20x9 or 18x9 wheels. I have read horror stories about people buying the "wrong" IFS and the engine doesnt fit properly. For the rear I am in favor of the ride tech 4-link and the Chasis works 4-link.
      Any suggestions, input, comments, thoughts, etc... would be very helpful and appreciated!!.
Size:  41.1 KBName:  IMAG0885.jpg
Size:  141.0 KBName:  IMAG0846.jpg
Size:  171.9 KBName:  IMAG0847.jpg
      Dec 2010
      N. Carolina
      I hope I can help. I am building a 69 fastback and have the same questions you do. I too have decided to go with the ridetech rear setup. What I have researched it looks like the Mustang 2 front suspensions are not the best when it comes to road racing. My dilemma is that I want to eliminate the shock towers which pretty much means I need to go with a Mustang 2 front suspension. I am guessing you are doing the same if you are installing a coyote engine. From what I have read the best of these are either TCI or TCP. I am by no means an expert and hope some mustang guys will jump in to help out. By the way 'cool build'!
      Sep 2012
      Country Flag: Finland
      You can remove the towers also with Griggs front suspension, and that is more performance oriented than any MII system, which is really not for road racing.
      Griggs is not cheap though. (With 20" wheels you will not go Roadracing anyway, so maybe the MII suits your needs ?)
      Jan 2010
      Long island NY
      Iam running the ridetech 4link and coils and love it, have not had a problem yet
      70 Mustang fastback 428 sb
      Dec 2010
      N. Carolina
      Quote Originally Posted by 1970 TT Rustang View Post
      What front suspension are you running?
      Dec 2010
      N. Carolina
      Quote Originally Posted by 69SSLS1 View Post
      My bad! I just read your post on my thread about the GW front suspension. Thanks!
      Dec 2010
      N. Carolina
      Quote Originally Posted by Tony@Roadstershop View Post
      Just to add to your choices , we also offer 3 different versions of components for the Mustangs. We have a crossmember only to attach to your original subframe. A complete replacement subframe if ( usually is ) your original subframe is rotted out... and also a complete chassis. For those that are wanting to use a ridetech or other rear suspension are leaning towards the subframe or crossmember and for those that are wanting to replace the floors and weld in a chassis are choosing our complete chassis for the strongest overall platform to base the project on.
      Chassis info... http://www.roadstershop.com/products...ustang-chassis
      Subframe and crossmeber info... http://www.roadstershop.com/products...ang-suspension
      Wow! Your products are a work of art. I wished I was not on such a tight budget.
      Jul 2012
      Greenwich CT and NYC
      if i had a project car like yours i would find a way no matter how long it took to budget the roadsterShop full blown chassis set up. it is so freaking awesome i so want that one day, maybe on the next build i do if i ever find a decent donor car.
      Aug 2012
      Pennsylvania
      My plan was to put a decent amount of money into the suspension and of course lots into the engine!!!
      Mar 2012
      migg ...... Keep in mind that horsepower isnt any good unless you can put it to the ground.
      Aug 2012
      Pennsylvania
      You are right about that!!!
      Apr 2011
      Riverside, CA
      guess i read the posts wrong.
      eliminated previous coment.
      As others have mentioned, Griggs, Roadster Shop, I would add Art Morrison and Cortex Racing.....
      none of those options inexpensive ofc.
      • Mike L.
