      Eastern Virginia
      Newb here from central Indiana & 86 Monte SS
      Hi gang,
      Glad I found this site. Here is some info on my Pro Tourer:
      Car: 1986 Monte Carlo SS
      Engine: 1995 LT1 (with fuel injection)
      Compression 11:1
      Cam: Comp Cams 306
      Rockers: Comp Cams 1.5 rollers
      Springs: Comp Cams “Behive” springs
      Tranny: 1995 T56 6 speed
      Rear end: 1986 Grand National 3.42:1 limited slip
      Brakes: 13” C5 Vette calipers & rotors front
      12” Vette rotors with F body calipers
      Exhaust: Hooker full length headers; 3” true duals, X pipe, flowmaster mufflers
      Wheels: Centerline Stars, 17X8 front 17X9.5 rear
      Tires: BFGoodrich 245/45 front, 275/40 rear
      Ignition: factory Optispark with MSD coil & 7AL
      Suspension: BMR rear arms
      PST bushings up front, Pole Position adjustable upper A arms
      Factory rear sway bar.
      F body 1LE 36mm front sway bar
      Other things:
      4” cold air intake
      Port match heads to intake
      Hurst shifter
      Impala SS cooling fans
      Goodmark cowl hood
      Hopefully someday I can get this thing on an actual road course to see what it will do. Eventually I will probably put a roll cage in it, & would like to put the 275’s up front & put 315’s out back, to do that I will have to notch the frame. Would love to put a Vette IRS in it.
      Sorry to go on & on,
      Scot
      Scot
      86 Monte SS
      Erwin,TN
      Cool project, man, even though I am most partial to Fords. Looks awesome!
      Jun 2005
      Ocean Springs, MS
      Welcome aboard Scot. The more G-bodies the merrier.
      Dustin
      Jun 2002
      Long Island, NY
      Welcome to the site .
      North Jersey
      Hey, good to see you on another site Scot! Welcome aboard!
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      dayton ohio
      good looking ride, welcome home.
      kevin
      POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
      lima, oh
      i think everybody from montecarloss.com is finding this site.
      Eastern Virginia
      Thanks everyone.
      Scot
      86 Monte SS
