      Jun 2008
      Acworth, GA
      FI cam tech question
      Can any of you guys tell me what it is about the camshafts that are for designed for fuel injection applications makes them unique? I am putting together a Gen I 406 SBC that I have intended to run fuel injection on (including already purchasing the FI setup and camshaft). It turns out that I need to sell the FI to help fund the finish of the paint and body work that is currently going on. I would like to put a carb on it for a while to get the car driving up and down the road and then just put the FI on it later when I can aford it again. I realize that the engine will obviously "run" with the combination of FI cam and a carb, but what problems am I likely to see? About the only thing I could see really being a problem is if I somehow wound up not having enough vacuum to pull the fuel through the carb. Anybody got any thoughts?
      Thanks in advance,
      Mike
      Central CA USA
      I'm not a cam expert but here are my thoughts:
      EFI cams generally don't have as much overlap to generate more engine vacuum at idle and low speeds. A carb will run fine with an EFI cam but could tolerate less vacuum and an ideal cam for a carb might have a little more low end but rougher idle due to the extra overlap.
      Jun 2008
      Acworth, GA
      Thanks, David! I was hoping someone would say I would be OK until I can buy the fuel injection system again. I could not think of any reason why it would not work (albeit not completely ideally), but I am not a camshaft engineer either.
      I found that you can post this type of question on Comp Cams' website and I will do so just to see if I can get any of the experts over these to give us any other insight. I'll post up any and all feedback I get just in case we could all learn something.
      Thanks again,
      Mike
