      Nov 2011
      Riverton, Wyo,
      Oil pan clearance
      I have a ls3 with autokraft pan. It is installed in 69 camaro with art morrison front subframe, I used morrison adaptor plates with energy suspension mounts, It sits aprox 1/8 about the steering rack, super close, I am thinking of changing adaptor plates to the ones autokraft sells. I see some look like they are offset a little wich would put the pan up away from the rack, any good advice on this as to what you guys may be using in the morrison chassis.thanks
      Mountain Springs, Texas
      I used the stock F body pan with my Art Morrison subframe. That is what they designed it for as far as I know. At least that is what is in all the photos on their website.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      May 2002
      Northern California
      You should be ok, the rack doesn't move and any engine movement will be upwards.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
