      Cologne, Germany
      ATS Clutch bracket question
      Does anybody know what the bent angle is on the ATS clutch bracket for first gen? And also are the holes for the 4th gen MC in the bracket at 45 deg from horizontal? I'm currently living in Germany and can't measure mine. Will be machining up a AL block similar to the Tick setup to put in a Tiliton MC that I already have, then bring back in August to put on the car while I'm in Detroit.
      1969 Z/28 Dropped 2" GW uppers, lowers, leafs w/delrin, QA1 coilovers w/450 lb/in, Unisteer R&P, 1" solid anti-roll bar, subframe connectors, Billet specialties SLX-45 18X8 and 18X9 with Toyo RA-1 245/40/18 and F1-GS-D3 275/40/18. C5 Z06 brakes, 408 ci LS2, Viper T56 trans.
      2007 Wildkart shifter kart with Honda CR125 engine.
      2004 Dodge SRT4 daily driver and track day car, stage 2, rear ARB, dropped 2 inches
      1997 K1500 Z71 tow vehicle
      Cologne, Germany
      Or I guess more correctly, what is the angle between the axis of the MC and the face of the plate?
