    Page 1 of 4 1 2 3 4 LastLast
    Results 1 to 20 of 73
      Jan 2009
      1970 Pro Touring DAR/T
      So the story goes...
      Once upon a time I had a 71 Dart that I turbocharged and was going to do body work on it over the winter. After removing a few panels and fenders, the car was diagnosed with cancer and had 6 months to live.
      It was sent down the road and I picked up a cancer free 70 Dart from Arizona to start a new build on.
      As you will see this build took and entirely different direction then the last build.
      Delivery picture from 6/10
      5/11
      8 3/4 diff, Large Bolt pattern hubs and wheels, Disc front brakes.
      And then the tear down started so it could go on the rotisserie.
      Found 2 build sheets.
      Back seat.
      Under the carpet.
      1970 Dart - Coil over K member, A500, Cuda Hood, lot of fun.
      https://www.pro-touring.com/showthre...-Touring-DAR-T
      1971 Dart, MP T70 Turbo, 318cid, 904TF, - SOLD
      Jan 2009
      Been looking all over for a 46RH. Found a few, all but one were to expensive and trashed. Went and checked out the one today at the bone yard but it turned out to be the non lockup version. I did however score a 42RH.
      Its not as stout but it should do the job for a few years.
      bye bye 904TF, hellow 4 speed OD!
      We are doing this build at my friends shop.
      http://www.gcrods.com/index.html
      USCarTool SFC's were fitted.
      Jan 2009
      Had the bottom of the car sand blasted for $200. BEST $200 I've ever spent!
      Only found one problem spot.
      Rear passenger trunk area.
      Jan 2009
      Making room for a fuel cell.
      Sub-frames installed. Just need to be grinded and seam sealed.
      Jan 2009
      Reilly Motorsports spring relocation kit was installed.
      Minitubs
      Patch panel in the trunk to replace the only rotten spot i've found on the car.
      Lower Radiator support installed.
      Jan 2009
      Test fitted some 315 35R17's on the Dart since the mini tub is done.
      Decided to step it up finally and pulled out the good camera.
      [/QUOTE]
      Jan 2009
      Whhaaaat is this? A Cuda hood on a Dart? I must have hit my head. :D
      [/QUOTE]
      Bye Bye torsion bars. You won't be missed.
      Hello HemiDenny K member!
      Jan 2009
      Trunk floor pan partially welded in at this point.
      Mini tub.
      [/QUOTE]
      Jan 2009
      Anyone interested in a K member for a Mopar A body. I HIGHLY recommend getting in contact with HemiDenny on forabodiesonly.com. Been absolutely great to deal with. Product fits perfectly, no massaging, no install issues, the guy knows what he is doing and does it perfectly.
      Badarts radiator support and Denny's K.
      Its going to look like jewelery once its powder coated. I'm just trying to decide what color.
      Jan 2009
      Anyone know where these go?
      I turned my back and the plasma cutter got a mind of its own.
      I think I found where they were at.
      Jan 2009
      ECI Mustang II "Big" Brake Kit for the front.
      http://www.ecihotrodbrakes.com/musta...nversions.html
      One more piece of the puzzle.
      27.5x19 Griffin radiator is mounted. Think it turned out nice.
      Jan 2009
      Hagen fuel door installed. No more crooked fuel cap
      Nice and tucked out of the way.
      Jan 2009
      Color has been chosen.
      Here is the test panel and multiple pictures so you can see how it changes based on the light.
      Loud and obnoxious, just like Ma Mopar liked them.
      Took a picture with the good camera. And I still can't capture the color correctly. Cameras have a real hard time with this color.
      Even the factory car I got the color from shows up different in every picture I've seen.
      3 stage paints are awesome.
      Can't wait to see how it shows off the body lines of the hood and the rest of the car.
      Jan 2009
      fuel pump is mounted.
      View from the back side.
      Put the Dougs headers in place so I can see where the lines need to run to avoid the exhaust.
      I'm pretty dang happy with the headers so far. They fit like a glove and clear the transmission crossmember.
      Jan 2009
      Fuel line, transmission lines have been run.
      Mounted the line lock and ran some of the brake lines.
      I need to remake the one line with stainless and run the front and rear brakes yet.
      Jan 2009
      Column is partially mounted.
      May 2009
      Minnesota
      Great looking build so far. What are your thoughts on the rest of the interior, and the motor? Keep the pictures coming.
      Jan 2009
      The motor is a 1990 360 so it has the roller valve train. It will be getting a refresh.
      Interior will have the custom dash, at some point a custom console.
      I've got more progress pictures to post to get you guys up to speed on where the build is now.
      Nice work, its looking great.
      Florida
      Looks great! Will be watching for more pics.
