    Results 1 to 12 of 12
      Cincinnati, OH
      Aluminum water pump
      You guys have any experience with a perfomance alum water pump? I bought a Summit Racing (SUM-311017 - Summit Racing Street & Strip® Water Pump) and it has leaked ever since I bought it. Of course I didn't know it till it was out of warrantee. There is no rebuild kit available and they offered a 10% discount on new one. Whipty doo! I will never buy another item from summit as long as I live!
      I need a new one or a rebuild suggestion any ideas?
      Thanks.
      Jim S.
      67 RS
      "driver "
      Central CA USA
      Find a rebuilder, they can fix it. I rebuilt my Moroso pump myself. Most tractor repair shops can do them, my local John Deere dealer is used to rebuilding tractor pumps because JD does not service the whole pump as a rebuilt exchange on many older models.
      DO NOT press out the bearing without supporting the housing in the cover plate area! If you set it on the block face surfaces & press it will break in half.
      There are two bearing sizes, early and a late which is larger. Moroso should have parts kits.
      Cincinnati, OH
      Thanks David, long time since we chated about Gulstrand on TC forum. I'd like to be running courses one day with my 67!
      You think Moroso makes these pumps for Summit and this small block long pump IS likely rebuildable? I have skills, I fix equipment for a living and can source parts fairly well. I'll get it apart. I has no miles on it.
      Jim S.
      67 RS
      "driver "
      Jul 2012
      eden ga
      I have that same summit pump for my nova but have not put it on yet
      Cincinnati, OH
      Sorry about that one 540. Mine was junk...only a 90 day warrantee too...good luck.
      Jim S.
      67 RS
      "driver "
      Jul 2012
      eden ga
      Quote Originally Posted by Quickboat View Post
      Well I have had mine for a lot longer than that but oh well
      Cincinnati, OH
      Quote Originally Posted by 5spd540 View Post
      The money lost is only half of the battle since you got to pull the SOB out once you find it leaking.
      Jim S.
      67 RS
      "driver "
      Cincinnati, OH
      I will pull it out and take it apart. If it is repairable as David thinks it is, I will list the parts I use on this thread for future reference.
      Thanks again.
      Jim S.
      67 RS
      "driver "
      Cincinnati, OH
      Anyone know exactly how to press this pump apart? I guess first, the pully plate must have the shaft pressed through it, then the shaft presses through the bearings out the back of the pump? I dont know how much pressure this housing can take. Its kinda chinsey feeling.
      Sorry about posting in the wrong place.....;-)
      Jim S.
      67 RS
      "driver "
      Central CA USA
      First step is to set the pump on a bench with shaft up and measure the pulley flange height, then check impeller vane to housing clearance.
      Ideally, you would never press on the shaft end to remove a bearing, this puts pressure on the bearing internally, but it seems to be the way everyone does it, the bearing is very strong, and the pressure isn't that high. SOME pumps have a lock wire slid into a groove in the bore with a matching groove in the bearing to lock it in place. I have never seen one used on a Chevy pump but on some tractors they use one. I always check for the lock wire though.
      You can press the bearing out rear of the pump, support blocks need to be set where the rear cover bolts on, but allow room for the impeller to come out. I use a bolt as a press tool, as the bearing moves down, the pulley flange will come up against the housing and come off as it goes. Once the shaft is out press off the impeller and pull the seal off.
      To assemble, press the seal into the housing first, Press the fan hub onto the bearing next, shoot some WD40 in the bore then push the bearing in from the front, flip the pump over and press on the impeller and watch carefully to get a small clearance between impeller vanes and the housing. The GM Overhaul manual has the clearance spec, I think it's .030" but that's a guess. Warm up the Aluminum housing so you won't have to push so hard with the press and there's less chance of galling the bore.
      Bearing kits here: http://motors.shop.ebay.com/i.html?_...mp+rebuild+kit
      But who knows what quality? I'd look for a Moroso rebuild kit first. Inspect the seal surface of the impeller and make sure it's not rough. If it's a long water pump, I'd expect the bearing to be the large one.
      Cincinnati, OH
      Thanks David, always out to help, awesome. I got some pics of the disassembly for the record. I pulled the hub of with a gear puller first then to the press.
      Jim S.
      67 RS
      "driver "
      Cincinnati, OH
      Pump bearing markings: TZP 06 size 1.5 x .75 x 2.125
      Mechanical Seal : 240714 and is a Type 7 size .625 x 1.5
      I cannot locate these items in my industrial books and have had no luck on the internet. Any help would be appreciated.
      Jim S.
      67 RS
      "driver "
