    Results 1 to 15 of 15
      Jul 2010
      Sacramento, CA
      GM's new Gen V LSX engine.
      Saw this picture of the new Gen V LSX engine. I would expect more information on it in the next few months. Its a 10 year old design that I am very familier with, lets see how much you guys can pick up on though:
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Dec 2009
      It's got a truck intake on it? lol...
      The direct injection look interesting but I'd like to see one in person. What is that pulley down low? PS or oiling? Thx for posting James!
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Jun 2009
      From Wasilla, AK. Now portland, OR
      could be the fuel pump lo to hi pressure
      1970 Elcamino ls3/t56, ricks/vaporworx, sc&c afx ,forgeline zx3, kore3 z51/ls1
      1969 Camaro ls3/t56, ricks/vaporworx, ride-tech,forgeline ga3,
      2024 ford maverick
      Lawrenceburg, TN
      The General Motors Co. Tonawanda Engine Plant has two new lines up and running, work is under way to clear out more room for them, as well as for a third line of V8 engines (Gen V) that will debut there in 2013.
      Thats Steve Finch, manager of General Motors Co. of Tonawanda Engine Plant, he's showing a V8 engine that the plant will produce in first quarter 2013. where employees are trained to build the new engine that will be used in light-duty pickup trucks
      I see extra hardware on the valve covers, which are probably for the injectors. The belt driven thing is probably a fuel pump.
      Chicago suburbs
      No overhead cams yet? Dang. Oh well, I'm sure the power numbers will keep rising regardless.
      Enfield, CT
      That big pump pulley is going to get in the way of a lot of swaps.
      '67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
      https://www.pro-touring.com/showthre...7-GTO-LS3-Swap
      Jul 2012
      Central IL
      I wonder if a set of Gen3/4 heads will bolt on to that block? For those that don't want to screw around with the DI.
      Jun 2009
      it almost looks like there is holes the the exhaust manifolds for a sensor of some type. i hope they are going to be running a wideband setup on them now.
      2024 ford maverick
      Quote Originally Posted by rallystyle View Post
      Running 8 widebands with the ability to adjust the fuel at each cylinder would certainly increase power and fuel economy.
      Aug 2001
      Connecticut
      I can't believe no one picked up on it.... direct injection.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Enfield, CT
      Quote Originally Posted by 68sixspeed View Post
      Thought that was common knowledge.
      Dec 2009
      What thread are you reading? It's mentioned multiple times...
      Ron in SoCal
      Ontario, Canada
      The thermostat appears to have been moved.
      The runners on the intake appear to have a larger cross section and more length.
      The holes in the exhaust manifolds could be for air injection, although I would think the lines would be installed before the engine left the engine plant. I think Andrew's guess is closer to the truth.
      That pump on the lower left of the engine is just begging to be damaged somewhere on the line. I would have thought they would have tucked it in a little tighter. Maybe after they get tired of replacing them.
      Ken
      My other car is a Vega.
      Aug 2001
      Connecticut
      ok, so my reading skills suck tonight!
      2006 Corvette Z06
