      Jul 2012
      69 camaro blow thru
      454 with vortex blow thru with carb box fuel pressure vaccum source were to hook it to no fuel on start up magna fuel 325 pump with magnafuel regulator when adjusted to get car run floods fuel out of carb what is the proper hook up for vaccum source to regulator
      Mar 2010
      Alabama
      It hooks to your carb hat so when boost is in carb hat pressure will raise...if it is hooked to manifold pressure will rise to late....boost reference port has nothing to do with it having no at start up though.
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Mar 2010
      Alabama
      Also if it floods out top of carb either your return line is too small or your floats need lowered on car. What size is return?
      David Butler
      Jul 2012
      Traverse City, MI
      Add reps to DButler for being able to decipher that mess..........
      Project thread - https://www.pro-touring.com/threads/...ouring-Project
      IG - @tc_chevelle
      Pocket replied!
      Feb 2002
      Springfield, MO
      Wow!!! Is that how the new generation talks?!?!?
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      USA
      Quote Originally Posted by shmoov69 View Post
      It must be texting shorthand ..
      Jeff Tate
      U.S.A.
