    Thread: motor swap
      Jul 2012
      motor swap
      hey guys
      i have a 1958 biscayne with a 235 6 cyl with a 2 speed power glide tranny , and would like to change the motor to v8 of some sorts ,, what you you recommend for a simple swap , easiest that is that would bolt up with out a lot of headache ???
      thanks for replies
      Loganville, GA
      A Small Block Chevy would be the easiest to put in, just need the motor mounts and frame mounts from a 58-64 Biscayne, Bel Air or Impala. Next easiest would be a Big Block. An LS engine would also go in with a little more work and parts. Any of those would be a good choice, just need to decide what you want.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Aug 2006
      What is your budget? What kind of power are you looking for?
      Jul 2012
      low budget sorry guys i am not looking for horse power just something simple to get back driving, something that will go in without a lot of trouble
      Jul 2012
      Hey guys,i found a 327 motor, came for a 60's truck or something like that , he said i could have and try it and if i like it pay him 150 if not bring it back and pay nothing ,,,you guys think it might be ok to try ? He says it needs a carb, it floods bad now. I know i will have to change motor mounts,,and do pips ,, what else, will the linkage work for tranny ?
      Thanks guys
      Jul 2012
      A guy sent me this
      When I ran the numbers on the engine I believe it said 1958 to 1962 passenger car, the 4 digit code for the date ended in "zero" that indicated it was built in 1960.The engine Number is 375659 and the date code is J280--look it up.
      This is for a 283 motor he is asking 350 ,you know i am looking for something simple ,dont see why the 283 wont just bolt up, being tha it came from a 1960 it should have the same tranny( cast iron ), even if i took my time and rebuild it before hand ?
      Thansk guys
      Jul 2012
      here is what i know so far 283 was 57-67, 327 was 62-69 so i have 2 choices 283 or rebuild mine ,i sure have learned a lot in the last few days , now i have to make up my mind
      thanks guys
