      Sep 2011
      Southern Ontario
      Quick update but still looking for some advice. I have been told to just tap into the 0-5 volt wire at my throttle pedal. While testing the closest that I come is about .8-3.8 volts through pedal cycle. Is this an acceptable amount of reference? I assume it is fine for the motor, but is this [shortened] reference good enough for my simple shift trans controller? thanks
      Nov 2004
      Page 10 of the installation guide shows a throttle calibration process. I would infer from this that it is learning your max sensor value, and will know you are at WOT when it sees that value. Given that calibration process, I'd wire it up and if it passes calibration you should be good.
      Note that you have to repeat that calibration anytime you lose 12v power to that module. That's a pain, but very important to remember...
      Sep 2011
      Southern Ontario
      Thanks again Ian!
