Thread: Transmission Advice
A th400 would work well for your application. The question you would have to ask yourself is, how much highway driving do you plan on doing. With 3.7 gears and a 1:1 final drive ratio of the trans, your RPM's will likely be high when out on the open road. If you are ok with that, no prob. There are many RPM calculators online that you can put these metrics in, with your overall tire diameter and they will tell you your rpm at a specified speed.
Another option would be a nice overdrive trans....
-Nick
