      Jul 2008
      Ft. Worth, TX
      LSX LS3 custom ground Pat G comp camshaft.
      Category: Engine - Intake/Fuel
      Price: $250
      Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
      Location (State): TX
      Item Condition: Used
      Shipping Information: Item Can be Shipped
      Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
      LS Engine?: Fits LS Engine
      I have a Pat G custom ground cam for sale. Cam is in very good shape. It is ground on xfi intake lobe and xe-r exhaust lobe. I am changing to a different grind for my ls3 heads. I am asking 250.00 shipped plus PayPal. P your email for pictures. Thanks Jason.
      Specs
      Duration at .050 242/246
      lift .621/.614
      Lobe sep 114 +3
      Grind number
      3018r/3733r hr114+3
      Birmingham, AL
      Can you confirm that it will work with an lq4 6.0 with the stock pistons. I am running stock ls3 heads. Stock valves, upgraded patriot springs. Any idea about PTV clearance issues? Any hp numbers? Rpm range?
      Stephen
      Jul 2008
      Ft. Worth, TX
      I have no way to check ptv clearance for your application. The only way is the put it in the motor and measure. The lq4 has a dish piston and not a flat top so it might work. It was previously in a 408 which had pistons with valve reliefs in which there were no ptv issues at all.
      Rpm band was 2800-6000 in the 408 with an ls3 intake. It made 465 to the rear wheels through a t56 and a 9 inch.
