      May 2012
      Iowa
      Tall Chevy spindles
      I would like to put tall spindles on the Monte without the drop to them
      Jul 2008
      Ft. Worth, TX
      Tall Chevy spindles
      I think L&H manufacture the only tall afx spindles with no drop built in.
      Loganville, GA
      Is this for the Monte in your avatar? The 73-77 MCs had the GM tall spindles already (same spindle on 70-81 F-body). Just checking to be sure.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      May 2012
      Iowa
      Thanks Randy67 I never knew that. But down I want to put bigger brakes on it.
      Loganville, GA
      You can do the 1LE conversion, plenty of info out there about it. Quick overview is 88-92 Camaro 12" 1LE front rotors and 78-96 B-body (big GM RWD cars) front spindles which are the same height as your spindle, just have caliper mounting out farther for the bigger rotor. There are kits out there from Baer, Kore3 and others if you want even bigger brakes like C5/C6 Corvette, check with them for that.
      1975 MGB Roadster
      2003 GSX750F Katana
      May 2012
      Iowa
      Thanks you for your help
