      Aug 2009
      Langley BC, Canada
      700r4 speedo Gear Housing?
      Where do you guys recommend I get a speedo gear housing for my 700r4? I need one that will work with a 45 tooth gear as well as the 45tooth gear and a 15 tooth drive gear too.
      Kevin Freund
      1961 Impala Drop Top
      Kevin,
      If you are still in need of the correct speedometer housing, drive gear and driven gear we can help. We keep all items in stock, however some driven gears are becoming hard to get, but we can always change the drive gear to get the combination you need. We will just need your tire size and gear ratio.
      Mark
      Bowler Performance Transmissions
