- May 2010
- 35
vapor lock issues with efi system
So I am having all the typical vapour lock symptoms. Hesitation, no power, and after a cool down period all returns to normal. Here is the setup:
302 at the 275hp mark
Fast ez efi system with fast external fuel pump kit
-6 fuel lines with an connectors*
fuel pump is mounted low and is gravity feed
Lines are routed away from heat sources
Return line is mounted low on the tank and away from pickup
Fuel filters are clear of debris
Tank is new no rust or dirt
Vent line seems to be working well cant say i have actually checked, but no rushing air when the gas cap is removed
The only other symptom is an extremely noisy fuel pump which has been that way from day one. The car only has about 5 hours on it. Any ideas? Also if I do go ahead and replace the pump, does anyone know of a nice quite external one that has worked well for them?
