      austria, where the kangaroos go skiing
      Country Flag: Austria
      axle play 10bolt
      can anyone tell me what the maximum play should be between axle and posi. i have a eaton posi and superior axles all replacement for my camaros 10bolt, that i bought a couple years ago from summitracing. since i have swapped to my 5speed i realized that if i´m not under load i have a knock in the back when cruising. theres slight play in the ring&pinion but far more if i hold the differential and just move the axles/tires. the axle splines look like new so i would say no wear on them.
      pat
      69 camaro, 418cui p1sc1, ridetech,forgeline, and some more money wasted
      Only play in that direction should be gear lash, should be little. Are the C-clip axles shifting side to side causing a knock?
