    Results 1 to 1 of 1
      Jun 2006
      Katy,TX
      Steering column 79-81 Camaro experts
      OK guys that have rebuilt columns. My 81 tilt felt loose at the end so looking in my shop manual and also some online like this one it shows a bearing and adapter. Dealer part #s adapter 7805822 and bearing(an actual bearing like a mini throw out bearing)#7805700. And the bearing looks slightly too big to even snap into the adapter!
      So I pull the column apart down there as well as a non tilt 79 and both have just a plastic piece like the adapter with just a rubber seal on the inside-#7825647 and outside# 7825648-both numbers dealer can't find. No real bearing on two different columns. So what's up?
      Here's a link to pictures of the plastic and rubber seal pieces together and part and the "new" bearing and adapter.
      http://forums.performanceyears.com/f...72#post4644572
      1965 GTO project car
      2004 Pulse Red GTO
