    Results 1 to 19 of 19
      Nov 2009
      the dirty mitten
      Can you gravity bleed this first then use a power bleeder in the reservoir? Or use one that sucks fluid out or pushed it up thru the bleeder? You say there is fluid at the prop valve, did you undo the fitting after the prop valve to see if fluid flows there too? Everything in the system new? Old rubber lines are known to swell and completely block off flow thru them
      Steve
