      Oct 2007
      Newark DE
      C5/6 ball joint specs?
      I was wondering if anyone has any measurements of stock C5 or C6 ball joints, both upper and lower, or whatever you have. Need to figure out where the actual pivot points actually are. Have the specs from a stock C6 but not sure what the alignment was so spindle height would be off due to caster/ camber.
      If you have a cutaway or CAD drawling with measurements spec'd it would be very appreciated. Really don't want to buy parts just to cut them apart, on a budget.
      Any suggestions on measuring without cutting or guessing?
      Central CA USA
      C6 LBJ center of pivot is the middle of the A arm flange. To find center of pivot push the stud to the left, place a ruler on the stud centerline & draw a line in the approximate pivot point. Push stud to the other side & repeat. "X" marks the spot!
      Auburn, WA
      According to GM's drawings, the UCA stud centerline is 2.9" from the tip of the stud. For the lower, the measurement is 3.450".
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Oct 2007
      Newark DE
      Quote Originally Posted by David Pozzi View Post
      Thanks David. That was my next course of action if no one had exact measurements.
      Quote Originally Posted by silver69camaro View Post
      Matt to the rescue again! Sometimes I think I should just pm the C6 questions to you. Thank you once again.
      May 2008
      Toronto
      So if I measure the distance between the balljoint studs when assembled and add 6.350" that will give me the pivot to pivot?
      Would you have the upper control arm pivot dimensions by any chance? I'm having a hard time finding them.
      Keith.
