      Sep 2007
      How to choose correct gearing?
      67 Camaro
      3200 lbs
      28" dia. M&h drag radial tire
      630 flywheel horsepower
      700r4 transmission
      Dana 60 rear
      Looking for ideal rearend gear ratio for quarter mile racing.
      Jun 2006
      Katy,TX
      HP peak on the motor? Want to run the quarter with all 4 gears or just 3?
      Generally want to be at the finish line at or 500 rpm above peak HP. Some guys do want to use all 4 gears on an OD tranny, others just 3 especially if does more street service.
      1965 GTO project car
      2004 Pulse Red GTO
      Sep 2007
      Looking to use only 3 gears for quarter mile. 630 HP @ 6500 rpm's
      Mar 2011
      Ca
      there are calculators to give you an idea of where you want to be, off the top of my head with a 28" tire with a 1to1 final gear you'll want to use something like a 4.11 or 4.30.
      Sep 2007
      Thanks Sam, I'm actually running 4.30's. A little difficult to control excessive wheel spin on the street.
      Nov 2009
      Elburn, IL.
      Sep 2007
      Thanks Chris
      Dec 2010
      Fredericksburg, VA.
      When I was drag racing Dust Off back in the 70's I was running a T-10 with a 4.88 rear gear and 28" slicks. I lauched and shifted at 7000. I would cross the 1/4 mile at 6500 in fourth gear. Of course the 4.88 is totally useless on the street.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
