Results 261 to 280 of 288
Thread: LSx 1967 Mustang
- Aug 2004
- San Bernardino, CA
- 883
The saw table is awesome! I cut a lot of tube today and was very surprised that my butt joints lined up really good. I am still trying to find the best way to mark angle cuts on my mandrel bends. Also trying to figure out how angle cuts move the pipes. Almost done with the inlet hot pipes. i have the drivers side tube mocked up but no pictures of it. Here is the passenger side merge collector to a 1/2" thick 3" tube to T4 flange.
Also these little guys showed up today. 83lb Holley EV1 injectors. I basically stole these things on an ebay auction.
10-01-2016 #2
- Aug 2004
- 883
I got most of the hot side done today. I think it turned out okay. Lets just say cutting and fitting mandrel bends is not easy!
I have a fingers gap between the crank pulley and the pipes. I had to re-route the pipes to make room for the lower radiator hose. I picked up some 90* silicone elbows and plan on running a 90 from the radiator and an aluminum pipe that will 90 to the straight outlet on the water pump.
Next on the list is to build the outlet from the turbo and over the valve cover. Then find a good location to drill a hole for the waste gate. I was thinking of putting it on the 3" 90* bend that enters the T4 flange. The exhaust flow would go straight up into it. Then i would tie it into the down pipe.
10-02-2016 #3
