      NJ/PA
      Radiator hoses - LSX 1st Gen.
      Alright guys Im wrapping up the little things and this is a big one on the list. I read that these hoses would work for my setup and the upper hose fits perfect. The lower on the other hand would fit if it was another 2 inchs longer. Im looking for another lower hose im guessing. What is everyone else running? This is a 67 camaro with stock subframe,Entropy radiator for an lsx swap in a first gen, stock height solid mounts, S&P adapter plates, 327 engine stands. Here are the part number that I have currently...
      This is my upper hose - Dayco 71620
      http://www.amazon.com/Dayco-71620-Lo.../dp/B000C0WMKO
      This is the lower hose - Gates 20450
      http://www.amazon.com/Gates-20450-Up.../dp/B000C2UABU
      67 Camaro - LSX454 w/ T56 Magnum
      I had a similar problem finding hoses that fit. I eventually went down to Napa Auto Parts with a pre-bent piece of wire. I found a Napa hose #7868 for the upper and #7196 for the lower. You will need to cut the hoses down, but a section of both these hoses work for the application. What I like about using a stock numbered hose, is that it's available at most stores. Just keep the numbers for future reference.
      Brett
      Ramona, Ca. San Diego area
      great info Brett!!
      67 Camaro convertible (Jinx)
