      Nov 2010
      68 Camaro RS Grill Question
      hey guys i have a question... Why does the outer plastic piece trim on the 68 camaro grill not line up with inner part of the trim... instead it does this weird overlapping thing. Is it Normal? and if so is it anything that can be done to make fit flush or can i buy a different piece that would allow for the trim to match up with each other?
      68 Camaro RS twin turbo
      Slow Lifted Jeep No TURBO :(
      Randal F
      May 2011
      Central FL
      The '67 RS grill has similar fitment challenges. The outer pieces should overlap the center section. Your driver's side definitely looks better than the passenger side. Does the passenger side outer piece sit that way when not on the car? If it does, then you'll need to replace it or heat it up and try to reshape it so it fits better. Also, check the sheet metal that comes in contact with the top part of the outer piece. Sometimes the underside of fender or front valence is not bent under far enough and pushes down on the outer piece.
      - David
      1967 Camaro - In remembrance of my friend Scott
      Nov 2010
      and Dan i couldn't tell u if I wanted.. my car had been messed with and the front end got hit at some time. So I don't know whats new with the front end or not. So I went ahead and bout a GM Licensed repro!! I am hoping it will be 40 bucks well spent
      Randal F
      Jun 2009
      Central FL
      Is it OE or repro?
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Nov 2010
      thanks David for the info... I went ahead and ordered a new left hand side!! My mechanic said it was pretty abused, so bending might not work. He even tried to bend it back.
      Again thanks for sharing the knowledge
      Randal F
