    Results 1 to 11 of 11
    Thread: Glowing Headers
      Nov 2009
      New York
      Glowing Headers
      Sorry for the duplicated post, was not sure if some of you engine guys get to the project updates.
      It's alive Better video later. So I got here running after running 5 minutes at 2500 rpm to break in the cam, my headers glowed red, which tells me the timing is to advanced, corrected? I tried a base timing at idle and set it with the timing light to 15. So when running the car at 2000 I tried turning the distributor clock wise it starts to run like crap. I'm thinking at this point I may be off by one tooth. Which way should I move the dizzy by one tooth?
      Any comments would be a great help.
      http://www.youtube.com/watch?v=H46FJskT9vo
      May 2008
      Chicago
      It also it probably lean. When in doubt take the distributor out and start over at tdc. It sure is not worth a rebuild.
      Nov 2009
      New York
      Glowing Headers
      I forgot I should have said I'm running fast efi
      Mar 2010
      Okinawa, Japan
      Most definitely lean, probably from a good sizedvacuum leak would be my guess. No way timing alone will turn headers red!
      May 2008
      Chicago
      Remember lean is mean, but in this case I would still say it is lean. EFI or not. I agree with Keith.
      Nov 2009
      New York
      Vacuum Wow I did not think of that one any good idea where to start with that one?
      Aug 2009
      Arizona
      I used to have to get my 67 Camaro through emissions here in Arizona. High compression big overlap cam and I would lean it out and retard the heck out the timing. So I agree with the posts above check for lean mixture but also timing. Retarded timing means the fuel is burning later than it should and can give the red header glow - good luck !
      Nov 2009
      New York
      Thanks Guys I will play with tomorrow. One question, could you set the base timing at 15 deg if the distributor is off by one tooth? Because at ideal I was able to set it at 15 deg. I do agree with it leaning out because the motor was also running very hot. I will also set it up to run rich through the EFI unit to see how that helps.
      If I try to lean it out and turn thdistributoror any more clock wise the motor does it start.
      I think the first step is to check it from TDC as pointed out above.
      John
      Sep 2011
      Pickerington, OH
      John, Could you tell me what kind of gauges you are using. I like the look of them.
      Nov 2009
      New York
      Quote Originally Posted by scottymonte View Post
      Sure they are http://www.marshallinstruments.com/ from here. they are no cheaper then others however, I like some of the features they offer.
      Nov 2009
      New York
      Ok guys good news Timing was dead on 12 deg at TDC, I thought I build the motor right . Well I went into the ECU and richened up all the AF settings and all was good headers never turned red, smoke allot more but ran it for 20 minutes and no problem.
      Here is a little better video of it running, could not stay in the garage even with the doors all open. Had to run in and out to adjust the idle.
      http://www.youtube.com/watch?v=KD9cHtjzdHU
      Thanks for all the help.
      John
