    Results 1 to 20 of 28
      May 2012
      Lompoc, California
      Project Name: The Phoenix's Revenge 69 Mach 1 G-Machine Car
      Greetings Everyone,
      I am currently building a 69 Mach 1 G-Machine and I thought I would share with you the progress I am making on it. The car has spent its last 3 years as a show car in California. However, as you all know an all original car all though may look nice does not drive very well in these modern times. I thought I would give the 69 an overhaul and give it the power, handling and drivability it deserves to go with it's flawless looks.
      The roll cage and the motor are ready to rock. Finishing up the rear suspension and then starting on the front suspension and paint work.
      Joshua W
      Specs:
      1969 Mach 1
      Color:
      Tangelo Pearl Paint from House of kolor (Satin Black Mach 1 Callouts)
      Suspension: & Brakes:
      Wilwood Big Brake Kits 13 inch Front & Rear
      (Lowered Rear Leaf Springs)
      Total Control Products Front Coilover Suspension w/ Custom Front Sway Bar
      Custom Fabed Roll Cage (10 point)
      Custom Fabed Rear Suspension w/torque Arm
      Motor & Engine Bay:
      351ci bored and stroked to a 408ci
      Holley Ultra HP Carb
      Edelbrock Victor Jr. Intake & Water Pump
      AFR Ported 185cc Heads
      Solid Roller Comp Cam
      March Black Anodized Pulleys
      Hooker Black Ceramic Coated 1 3/4 Headers
      Be Cool Custom Radiator and Dual Electric Fans
      Moroso Racing Oil Pump and Pan
      MSD Pro Billet Distributer
      ARP Black Anodized 12 Point Bolts
      Wilwood Black Anodized Tandum Master Cylinder & ProportoningValve
      High Volume Electric fuel pump
      Drive Train:
      Ford 9inch
      Strange Engineering 4.11 Posi
      Aluminum Driveshaft
      Monster AOD Trans
      B&M Pro Stick Shifter
      Wheels:
      Vintage Wheel Works 17x7 Front / 17x9 Rear v 40's (Powder Coated Black)
      Others:
      Custom Steering Column w/ Momo Quick Disconnect Steering Wheel
      Custom Toggle Panel & Push Button Start
      Auto Meter Gauges
      Corbeau FX1 Seats (w/ 3inch 5 Point Harnesses)
      Custom Hand Brake
      Custom Wiring Harness
      battery (Relocated to Truck)
      Custom Fabbed Body Panels
      Blacked out Mach 1 (Bumpers & Trim)
      Thanks'
      Joshua
      Ramona, Ca. San Diego area
      wow, way cool parts. Nice start to a cool car. Love the cage. I will be watching this build.
      Welcome to PT.COM.
      67 Camaro convertible (Jinx)
      May 2012
      Lompoc, California
      Quote Originally Posted by 67 ls1 vert View Post
      Welcome to PT.COM.
      Thanks! There are some amazing builds on this site and I am picking up a ton of useful tips and neat ideas from projects just like yours!
      May 2012
      Lompoc, California
      Aluminum vs steel driveshaft? Anyone have and good recommondations and why please.
      Thanks'
      Joshua
      Ca
      Crown Vics have aluminum stock so sourcing one shouldn't be a problem. They are one-piece as well. They should be available at the junk yards in California. The draw back is that they are generally larger in diameter potentially interfering with exhaust and other components. Reducing drivetrain weight is always a benefit, at least in a street car. I was going to put one in my '73 Duster, but the clearances are too tight with the extra diameter.
      May 2012
      Lompoc, California
      Quote Originally Posted by MichaelUser View Post
      Good info, we are going to have to modify the exhaust anyway because of the unique rear end setup so clearances should not be an issue since were doing a lot of modifying. Thanks!
      Sydney, Australia
      Country Flag: Australia
      Well, anything that spins is going to spin up faster if it's lighter (less mass to accelerate)....so if you've got an engine that loves to rev, everything you can do to lighten the rotating mass is a benefit.
      In your case....I'd probably be leaning to a quality alloy unit.
      My own choice was steel....based on the use of my car, and its a big cube Pontiac....its not built to rev past 5500 rpm.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      May 2012
      Lompoc, California
      Good call! I have a hydraulic cam in mine which is great up to about 6500 then dies off. The motor is a pure torque motor but not necessarily all about top speed. I don't plan on reving to the moon on the street so I would like a driveshaft that does saves weight but is durable enough for the street as well.
      Nov 2007
      Manhattan, KS
      awesome build
      May 2012
      Lompoc, California
      Quote Originally Posted by fordrule View Post
      awesome build
      Thanks man! Weve got to represent the Blue Oval a bit don't you think! Great job on your project too!!
      DFW, TX
      Loving the color! Ill be watching this build for sure
      May 2012
      Lompoc, California
      Quote Originally Posted by MattWash08 View Post
      Thanks for the comments. House of Kolors makes some badass colors but none better then Tangelo Pearl! The car has 6 1/2 weeks to be complete. This will be fun!
      May 2012
      Lompoc, California
      I know what wheels I will be running by tires is another thing. I need a set that will glue to the road like never before. Their are so many good tire manufactures out their and they all seem to have pros and cons to their tires. I would like to know what brand tires you guys like the most and why. Nitto, BF Goodrich & Bridgestones all seem legit so any input would be great.
      Thanks'
      Joshua
      Mar 2012
      British Columbia
      Wow this car is looking great already, is that last picture the gas cap? If so, I definitely have gas cap envy haha!
      May 2012
      Lompoc, California
      Quote Originally Posted by E-Vukets View Post
      Thanks much for the comments. It sure is the gas cap. All of the chrome trim has been treated to a satin black finish to give the car that all out menacing look. The radiator, radiator cap and catch camn were also powder coated as well. It took over 30 hours of powder coating to get the cap and catch can logos to come out just right. Their is 6 diffrent colors of blues used in the logo just like in the real Be Cool logo!
      Sydney, Australia
      Yeah, that Tangelo Pearl HOK is an awesome colour!
      Tyres??? I like Nitto, good price vs a good tyre...nice balance between cost and quality. I've bought Invo's for mine, but its being built as a road car. I had NT450's on my previous T/A and thought they were a very good tyre...the Invo is supposed to be a step up.
      If you like to AutoX or Track run your car, you might want to be looking at something softer again, though.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      May 2012
      Lompoc, California
      Their has been a lot of people pushing me towards Nitto so thanks for the info! Great project by the way!
      Sydney, Australia
      Thanks.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      May 2012
      Lompoc, California
      Custom Steering Column:
      Just finished mocking up my custom steering column complete with Momo steering wheel. Nothing like have a splined removable steering wheel!
      Houston, TX
      From show car to race car...awesome start.
      Asa Walker
      Houston, TX
