      Feb 2008
      Chicago
      04-06 GTO front seat problem
      Hey Guys,
      I just finished installing 04-06 GTO power seats in my 65 GTO. After making all the necessary modifications to the seat tracks, I have them securely installed. I tested both seats before and after installation and found all to work as expected. Now, for some reason, the driver's seat will only move forward or backward in 1 inch increments every few seconds. It seems as if the motor is "overheated" or something and just stops working temporailly. While trying to diagnose, I held the slider button in the forward postion then toggled power and found the seat would move, but only if I toggled the power every few seconds. The same going in reverse. I initially thought maybe the seat was binding but now it appears that is not the case and looks like an electrical issue. Has anyone experience this before?? Also the pass seat appears to be working fine (so far). Thanks for any help
      Ken B.
      65 GTO
      67 Firebird vert
      Dec 2008
      Detroit
      Have you double checked your ground? I know weak ground wire would cause the motor to "under perform"...
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Jun 2009
      From Wasilla, AK. Now portland, OR
      i am not sure on the gto seats but if it has a memory setting there is a position sensor that knows where it is. you may have to move the seat all the way forward then all the way back so it knows where its at. same with all the movements of the seat
      1970 Elcamino ls3/t56, ricks/vaporworx, sc&c afx ,forgeline zx3, kore3 z51/ls1
      1969 Camaro ls3/t56, ricks/vaporworx, ride-tech,forgeline ga3,
      2024 ford maverick
      Feb 2008
      Chicago
      I was thinking about the ground.....I had to remove it and quickly put it back without checking it too closely. I'm not sure if there is a position sensor but I will check it out as well.
      Thanks Guys
      Ken B.
      65 GTO
      67 Firebird vert
