      Central Florida
      68 Camaro BBC frame mounts ????
      Anyone have any pros and cons on using repro frame mounts verses NOS frame mounts, NOS ones are almost twice the $ of repros. Looking for some feedback on those of you have used one or the other. Any problems with repros that I should look for? I would be willing to buy NOS if the repros present problems.
      Thanks guys
      Jack
      DUBUQUE IA
      i bought both no problem with repos. i had problems with the aftermarket motor mounts not setting down on the frame mounts. i was getting my parts from npd. i ended up getting a set of motor mounts from the dealer and that was the key. i called npd and told them about the problem so maybe thay solved the problem. i also tried some aftermarket mounts from around town part stores and all had the same problem thay were to narrow to fit on the mounts.
      pro tc
