      Breaking up in third gear
      I was running the TA testing for an upcoming road course event .
      It would run through 1-2 then in third and forth it would breakup
      And loose power surging like it was running our of gas.
      I have a 1/2 pick up from robbmac feeding a Holley
      Blue to 1/2 lines to a Holley dead head pump into a Holley
      950 hp carb. This is a old combo nothing new that has worked well in the past at the drag strip.
      Dome things that struck me as possible issues the engine was running hotter that it has in the past showing 220 . Also runs with the temp below 200 seemed clean. Is it vapor lock or the pump ???
      Oh engine is a Pontiac 455 about 550 hp fwiw.
