      Jun 2009
      Bump steer question.
      I've been building up my front subframe on my 2nd gen 79 TA. I'm wondering if I will run into bump steer issues and should purchase the baer tracker tie rods or equivalent brand because of the additional camber/toe. urrently whats on/going on the subframe:
      Global west G-plus upper control arm w/ del-a-lum bushings
      Global west G-plus lower control arm w/ del-a-lum bushings (coil over)
      QA1 coil overs
      AGR 12:1 fast ratio steering box
      Stock spindles
      Larger sway bar
      Either 18 or 17" wheels
      Mar 2012
      Not a question that can be answered without first measuring or plotting bump steer on your car. Bump Steer kits are only worth it if the car actually has bump steer issues.
      Shane Hill
      90 Mustang LX with 4.6 4v and 105mm turbo 7.72 at 194mph on drag radials
      65 Mustang- MTF C6 ifs, Torque Arm, Watts Link, Ridetech shocks, Boss 302 Coyote + T56
      Central CA USA
      Second gens have toe in on bump, it isn't nearly as bad as toe out. You can correct it a lot by just raising the idler & steering box where they bolt to the frame using the slop in the mounting holes, but you need to measure toe hanged to get it right.
      David
