      Nov 2010
      Novi Mi
      TR6060 Questions - from Corvette
      Hello,
      I haven't really posted a project build yet because I am still doing some of the thinking through of my project, and I bought a TR6060 out of a corvette last week. I got it today, and was looking at the rear housing, and it should easily mate with the transfer case I plan to run. I know I need to shorten the output shaft before that can happen.
      I was wondering if I could setup a shifter so I don't need to change the transmission internals since the shifter lever mount comes out of the front of the transmission. By running a remote shifter linkage I think I could do that as the engine will be set back into the firewall anyways.
      If I were to keep the standard input shaft would I need to also build a custom bellhousing? Isn't the input shaft on a corvette tr6060 longer than one from a camaro, cts-v, challenger, or mustang?
      Feb 2012
      Ohio
      Quote Originally Posted by olason View Post
      Hello,
      I don't know what your building.
      But I have a 2010 Camaro 6060. It came with the stock shifter and of course it hangs out the back also.
      I bought a shifter to install on the top. Its called a t-56 shifter but it was designed for the 6060.
      The last thing I wanted was to have the back of the 6060 replaced... (some guys will tell you this is the only way).
      The info you need is here.
      I went with this guys exact same part, even though I am running a pontiac. That "dimension" is for a stock camaro.
      They do not list this part and Red has retired. It is like 1 inch over and 3 inches back. Since I am going with a custom console I figured that was pretty close, obviously the camaro is different from the GTO. I can have an adjusting bar welded if needed. Its a "no notch" shifter(notches are in the tranny). Obviously you distance will be different if your not using a camaro. I will make mine fit, it sounds like they will work with you on the size and distance, your best to mock it up and give them a call.
      Mcleod: 85-403-124-07 Take a look at his pics and you will get an idea(page 2 info).
      http://ls1tech.com/forums/conversion...68-camaro.html
      http://www.mcleodracing.com/categories/Shifters.mcl
      http://www.streetrodderweb.com/tech/...ion/index.html
      3 inches is the max the shifter can be set backwards or forwards btw.
