    Results 1 to 13 of 13
      Nov 2010
      orlando fl
      Wrapping headers
      What do you guys think about wrapping headers? Just like to hear thoughts.....my floor boards are burning from those headers
      Loganville, GA
      Coating the headers would be better, but wrap does help some. My headers are wrapped on the Camaro but they still give off a good amount of heat. Heat shielding on the floors may be a better solution, like a reflective heat barrier on the underside and more insulation on the floors inside.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Sep 2008
      Jacksonville, Florida
      Stainless or mild steel? The wrap does hold moisture and retains heat in the tubing accelerating deterioration. Mild steel with start scaling within weeks. Might get a year out of the headers. Stainless is a better alternative to wrap, but the quality of stainless matters.
      I have a turbo car with everything wrapped, but I have 321 stainless for tubing.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Mar 2004
      Mid-Michigan
      Spend the money on JetHot and a good heat barrier. Like Craig said the wrap will ruin a mild steel header very quickly. I had the steel headers on my truck JetHot coated in '01 and they still look like new.
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Mar 2011
      Ca
      better off with a coating, i used Jet Hot, a friend of mine wrapped his headers and they were rusty looking within the first month, i'd only use wrap as a last resort. you may even want to look into DEI insulation for the floor itself before wrapping the headers.
      Nov 2010
      orlando fl
      Thanks guys...I definitely think insulation is the way to go.....so you suggest on both sides of the floor boards?
      Jan 2007
      CT
      I wrapped my headers since i bought them used and they had some surface rust on the jet hot coating. After 10 years i just re-wrapped one this year and there was no rust other than the surface rust that was already there.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      Loganville, GA
      I would put a reflective barrier on the underside and insulation on the inside, to keep the insulation from getting wet and possibly causing rust issues.
      1975 MGB Roadster
      2003 GSX750F Katana
      Mar 2011
      Ca
      Nov 2010
      orlando fl
      Are those for under the car or under the carpet?
      Jan 2007
      CT
      http://www.secondskinaudio.com/index.php/products
      they have very nice product and are affordable.
      I used a combination of the automotive vibration mat and the thermal insulation mat.
      ________________
      Nick S.
      Mar 2011
      Ca
      the adhesive back can go on any surface provided you clean it well, the thicker mat is for inside use.
      Mar 2012
      second skin audio also make a sprayable heat barrier
