      Feb 2010
      Corvallis Montana
      Speed Tech this one is for you!!
      So I just got it my torque arm in last fri I got it from Jegs at the same time I got a fab 9" from them the kit I got from them is the 9" kit but I don't know if the kit will work with the housing I asked them at the time I placed the order and was told it would all work together hope you can help me with this thanks!!!!!!!!!
      Feb 2010
      Corvallis Montana
      this is the rear end Jegs told me would work with this kit hope this helps
      Indianapolis, Indiana
      Don't know if this will help, but it was on Speedtech's Website. Similiar housing:
      http://www.superchevy.com/technical/...all/index.html
      Ben Mowery
      67 Firebird -Powered by Pontiac w/ RAM AIR V.
      You should call Speedtech and ask them directly.
      ​John Parsons
      St George Utah
      what he said ^^^^^
      Not sure how many Jegs has installed lately?
      Normally when someone wants a fab housing we have them shipped directly to us to install all the brackets in house
      About the only issue you will run into that I can think of is the rear lower torque arm mounting brackets will need to be modified to fit the housing the ones that come in the kit are for a standard Strange housing.
      you will need to assemble the third member and install it and the pinion mount install the housing on the torque arm, and see how the rear tabs will mount keep the pinion angle at 0 when setting it up to tack the rear tabs on.
      any other questions? 1-888-467-1625
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Feb 2010
      Corvallis Montana
      Thanks. Blake!!!! This is good news can't wait till I have all this in the car I will be ordering my drop out this week and I will call you when I get closer to bolting it in one more ? I have the 1/2 hight mounts on the car now the ones that come in the kit are for stock hight right? If so I can cut them down to fit thanks a million!!
      St George Utah
      yes you will need to cut the supplied rear body mount to the correct height to work with the 1/2 height body mounts,
      Blake Foster
      435-628-4300
      St. George Utah.
      Beach Park IL
      Quote Originally Posted by killer69 View Post
      This made me smile, thanks!
      Donny
