Thread: 69 Camaro 'Hot' Warning Light
04-18-2012 #1
New to Pro-Touring
- Aug 2005
- 14
Just swapped out stock style iron heads on my 69 Camaro for a set of Aluminium AFR's. Running a completely stock wiring harness with stock dash. My 'Hot' warning light (idiot light) sending unit is 1/2" NPT threads and the AFR's have a 3/8" NPT threads.
Does any body know of a stock style idiot light sending unit with 3/8" NPT threads. It has one wire going to it and I am pretty sure that when it gets to a certain temp, it goes to ground to complete a circuit and then the light comes on in the dash.
I am running some aftermarket gauges (mechanical oil press, water temp, volts), but want the idiot light to work also.
