      Mar 2010
      Alabama
      Holley hp power source
      On my power harness I know it says connect straight to battery. I am using a battery terminal like picture I posted can I connect hot in one allen port and ground on ground side or do I need a different type terminal? I am using a yellow top optima battery. I just want to be sure I get the best hot and ground source. I would think what I have would be fine but I may be wrong. I want to do this right one time lolName:  battery terminal.jpg
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Jun 2005
      Lynnwood Wa.
      I would not connect it directly to the battery, I would look for an empty tab on the fuse block or steering column.
      There usually needs to be one direct 12 volt connection and one switched connection.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Houston, TX
      Quote Originally Posted by Ollie8974 View Post
      Why wouldn't you connect directly to the battery? Doesn't the HP harness have its own fuse?
      If I were to do the install, the above terminal should be fine.
      Tu Ho
      Firebird V2-LS swap
      Mar 2010
      Alabama
      It does have the fuse inline. It is suppose to go to battery I was just making sure this terminal would be okay to use.
      David Butler
