      Nov 2009
      New York
      Power steering Question Saginaw pump.
      Hey guys sorry could not find any other place to post this question.
      On my 69 Camaro I've installed the March pulley system, the Power steering pump is a saginaw with a female 5/8 - 18 inverted flare I need an apter to go to the female stock hose.(looks like an AN-6)
      Anyone know where to buy this?
      Few other questions, can I just buy a new hose and are the pressure valves in the pumps the same from the new to the stock Power steering pumps?
      Any help would be great.
      Jun 2009
      Central FL
      David Pozzi recommended me the PS lines from a 73 (I believe that was the year I searched for) Nova, as they were male on both ends and it worked perfectly. I have a Saginaw (GM Type 1) pump with a 3rd gen steering box.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Nov 2009
      New York
      Quote Originally Posted by Vicinity View Post
      Dan thanks, Looks like the 70-72 photos of that hose matches my hose with a male end Now you have me thinking could I not cut the end off and replace it with a male 5/8-18 I have a flaring tool which does a few sizes?
      John
      Jun 2009
      Central FL
      Quote Originally Posted by jtm311 View Post
      John
      I suppose you could, but I like hydraulically flared lines as it's almost a guarantee of no leaks. And the last thing you want is PS fluid all over your engine bay. I had that happen recently (due to something else), not fun.
      Dan
      1968 Camaro v2
      Nov 2009
      New York
      Agreed my local auto shop has one of the lines for 17.00 I will pick it up and see how it fits.
      Thanks again,
      John
      Nov 2009
      New York
      I wanted to update you on this. The Nova line did not fit the Pump side fitting it too large. The good news is I was able to unscrew the pressure valve from the old one and replace it in the new pump.
      John
      Jun 2009
      Central FL
      John
      I checked on what I had, it was a 1974 Nova line.
      http://www.classicindustries.com/nova/parts/70270.html
      The 72 might have been different.
      Dan
      1968 Camaro v2
      Nov 2009
      New York
      Thanks Dan the guys pulled a 73 for me but it looked different. I think they offer two versions in 73. No worries I'm glad I looked at my old pump to see the fitting swapped out.
      John
