Thread: Covan's 79-81 Camaro panel fit
04-11-2012 #1
Well went to slide it in after putting in the gauges to test fit it figured the mounting holes might be a little off. Wouldn't go in! the center portion where the gauges are was almost 3/8" taller than the original, mainly along the bottom. Also the addition outer piece around where the center A/C vents are needs to be remove at the top as it hits the dash. Don't know why it is there anyway.
The mounting holes are also off.
I used one without holes and also have one with I was originally going to use(for sale) with the 3 3/8" holes and both hit in the same spots so it is their mold.
1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
1965 GTO project car
2004 Pulse Red GTO
